snowbrd84
Thread starter- Joined
- Sep 23, 2012
- 215
Couldn't get above 3,800 RPM and had tapping from starboard valve cover and high compression in number 8 cylinder. Ended up being a wiped intake cam lobe - thanks to everyone's help getting that figured out in this thread - https://forums.iboats.com/threads/high-compression-in-1-cylinder-7-4-carb.768144/
Here's the destroyed lifter and could actually feel ridge on the camshaft:
Boat is in the water at marina slip, and I don't have a trailer, so doing this in-boat in the water.
So here we go - 3.5 hours this morning to drain the oil, empty the water tank (it will have to move to remove camshaft), get the intake manifold off, valve covers off and lifters out. Also cleaned up the intake manifold surfaces to be ready to go.
Camshaft and lifters get here today.
One question I have is what do you all typically do for resealing the intake manifold? The manual lists multiple different sealants, one of which is $50 which seems overkill. I was going to rtv top and bottom of rear and front strip gaskets and then spray both sides of the new manifold gaskets with Copper spray and call it a day. Is rtv around all the ports really necessary, if so, is it on both sides of the gasket?
