1972 Mercury 402 lower unit off but stuck in forward
twsmith54
I replaced the impeller and when I got it back together I couldn't get it to shift to neutral. Admittedly, I kinda forced it a little. Anyway, I've taken the lower unit back off and have read every posting I can find about this. Here's where I'm at. With the lower unit off when I turn the drive shaft clockwise (looking from above) the propeller turns forward. The propeller clicks if I twist the propeller clockwise (looking at the propeller from behind). When I rotate the shift shaft I don't really feel much resistance and I don't get neutral or reverse. I do have the factory manual but still can't understand how it could be stuck in forward. What did I break? Your help is appreciated.
flyingscott
If you put the motor shifter in forward and the lower in forward really can't screw it up.
Some effort is required to turn the shift rod to get neutral.----There is a strong spring in there.----Use a vicegrip !
twsmith54
Thanks racerone. The shift rod moves freely with no resistance. 90 degrees freely. It like it's stuck in forward.when move the shift rod counter clockwise it moves with no effort pas the neutral location and reverse location. Any ideas?
twsmith54
Nevermind, I just broke the darn housing trying to remove the propeller shaft and carrier. It FUBAR now. Ugh. Time to find a used lower unit. Not too happy with myself.
jimmbo
Basically the shift Shaft is rotating the Cam, which pushes the Cam Follower in, moving the Clutch Dog. When there is no/little contact between the 2, the unit is in forward. Looking at the Cam you can see it can be rotated a fair bit in the wrong direction(no shift action) with little/no contact.
Sorry to hear about the busted Housing. Just be careful with the replacement, as you will have to go through the same Process to get it installed
