Re: 1973 Evinrude 65 HP no spark ever...any ideas?
Hi Mr Capt Bob...<br /><br />Welcome to the list.. (wanted to be the first to say that to someone since I got here
<br /><br />Now, to the problem.. have you checked that power is actually getting to the motor when the key (ignition)is on? do you have a test light that you can test this with?? since you say you have no spark, I am guessing it turns over ok.. so it probably has power.. what I have done in the past is to immediatly check all connections, one corroded connection can naff up the whole show.. but start testing at the ignition feed and work your way backwards.. but no spark at all sounds like either a fuse gone, the ignition key dead.. or a fubar powerpack.. If I remember correctly, there is a fuse on the wiring on the back.. but I can't remember the color of the wire its on.. <br /><br />hopefully Schematic is still on the list today. he is abit of a legend with this stuff and can probably rattle off a dozen things to test of the top of his head...
<br /><br />rgds<br /><br />Frank<br /><br />just want to make sure its not something simple before you start pulling things apart..<br /><br />I have an outboard of similiar vintage and I just had to replace my powerpack.. very expensive.
