redneck joe
- Mar 18, 2009
- 16,242
ahhh... didn't come across that tidbit in my middle of the night researching. Thanks.
Going to bury the lines tomorrow.
The ones that are used down here come in widths if 18", 24", 30, 36, 42, 48, 54, 60I bought one, sent it back. Leaks and other issues. What i learned there was most are made solid this was all tubes with threaded connection s. Way too many future leak possibilities. Moat others appear to be solid. Welded i guess. In looking for replacement my challenge has been maximising my avail space against standard sizing which appears to be 4' and i have 7' so i lose ~40% avail heating space. Trying to work on that one or thinking soft copper coils.
garbageguy - total head and head loss, not sure what you mean and not getting much (that I understand) from the internets. ...
I did have the piping system up and the flow was adequate and I still had valves to close so yes, all good.Apologies for delayed reply - those are fluid hydraulics (engineering) terms
After reading thru all this after my original reply, looks like you are getting what is likely more practical info - for you (and me too, learning every day is good)
to answer your question
Total head = (static head+velocity head+pressure head) - head losses. That'll give you a "system curve", then compare that to a "pump curve", and select a pump that will satisfy the system curve in a range where the pump will happily operate. It's an iterative process.
But, since your situation has been addressed many times over the years by others - going thru the rigor of first principles is probably overkill here.
I was looking at it like this starts from first principles, and at that time you had no other replies. At this point you've likely received info that is of more practical help for you. To me, engineering is the practical application of technology - and the user of that term, engineering, gets to decide what is practical, and what is technology.
that tubing is very prone to exploding when one forgets to either have pump running in daylight or not draining after use. i did use that for my proof of concept. I've had two friends try it out and it is not a permanent thing to use and in my application i need a product to last many years as well as be more idiot proof.
Aa I said earlier, the #80, 3/4” HDPE in my system is over 25 years old. No explosions yet….lolthat tubing is very prone to exploding when one forgets to either have pump running in daylight or not draining after use. i did use that for my proof of concept. I've had two friends try it out and it is not a permanent thing to use and in my application i need a product to last many years as well as be more idiot proof.
