92 Johnson 55 Lower Carb Bowl Fuel Nipple Connects to?
Shinyboat
Upgrading a 91 Johnson J50JEIA 50hp to 92 E55RWLENM 55hp carbs. The old 50hp bowls are plugged. The new lower carb has an extra fuel nipple (#22) facing the air box (it clears below). What is this supposed to connect to?
The 55 was likely a manual start motor.----That nipple is to feed fuel to a manual primer pump.
