Those darn blue VP drain plugs
Donald0039
I have one of these drain plugs in each exhaust risers as it's closed cooling. Went to screw one back in getting ready for initial startup and it snapped. Looked at the other one and it snapped unscrewing it in the fall but I did not notice.
Do they not last very long? Cheap plastic? Blue is bad luck?
How to get the broken piece out? Not a lot of clearance going straight down. Only a few inches.
What is needed is a 1/4" by 3/4" long lag bolt that is LH threaded. The stuck piece has a hole in the middle I believe.
Good thing it's plastic so no corrosion holding it in.
Not sure this is an improvement over small brass drain plugs with NPT.
alldodge
Replaced mine with Hardin Marine stainless steel ones, they will not break. Blue plugs are ok but need to be replaced every 2 to 3 years
alldodge
Most drill up thru and then use flat blade screw driver or easy out
Lou C
Dump that plastic garbage! I have the original metal plugs in my 35 year old OMC…
Donald0039
These blue plastic plugs seal with an o-ring and are not NPT. So normal brass NPT plugs will not fit/seal.
Lou C
What about the Hardin Marine ones designed to replace the Merc plastic ones?
alldodge
Don't go there, will be a long con-vo
The brass fitting that screws into the block is the standard 1/4 NPT. The NPT changes it to the Merc thread which uses the Blue plug or Hradin Marine SS plug
Donald0039
Donald0039
Mine is closed cooling. These plugs only drain the exhaust elbow.
I am too cheap to buy the Hardin or CP stainless ones
3/4" long 1/2-13 bolt, with washer and O-ring. Under $1
Donald0039
So I have the older VP part number #3849500. They were superceded by #21114622.
The one that snapped has a hole in the center. Which makes them weaker I would assume. But is a good thing for inserting the screw extractor after the plug snaps.
