redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,332
Morning all.
We put in an inground pool about a decade ago and we never have had any good shade until about 3-4 pm. Now that we are a decade older, as our friends, shade is becoming a little bit more important so ive been planning a 12x8 cabana for a year or so. Finally starting, have main posts in with the structure to support the roof.
Now i'm in the planning for putting in a solar heating system on the roof and have a couple of questions with the second answer being dependant probably on the answer to the first question.
25k gallons. Primary pump is a hayward 1 hp that handles everything within the parameters of the filter. We are plumbed with an additional in/outlet using a 2" pipe that i can add another pump to run independently of the primary.
Pushing water about 30 feet horizontally then 7' up then thru the roof system then back down to the pool.
Roof will be in three sections of 4x8 so the pipes will be in three sections. Planning a manifold type approach (more about this later)
I think that covers the basics so now the questions.
Do i utilize existing pump and plumbing and add a diverter valve after the filter?
Do i add second pump to handle heater only?
Think of advantages and drawbacks to dual boat motors plus adding second allows for a more free flow as it would only go thru one strainer basket not a sand filter and three baskets. Not sure I'd need the extra flow? The extra pumps I'm looking at have a 50+ water lift range on a 1.5 to 2" pipe on about 6800 gph.
Next part is output lines to the roof.
Lines on pump will be 1.5 to 2" and im thinking with the gph it will flow too fast to pick up much heat. I can add a valve to retard the flow but that might put extra work on the pump long term? So my thinking is twofold. First would be a manifold into the three sections of the roof. That begets the question of what size? If the input is two inches should i split into ?? size? I'm thinking into one inch for a total of three inches to slow the flow to keep water in the solar panel longer to absorb heat better? Then back to two inch to again assist in the slowing of the water flow for heat gain?
Lastly, could i go from the two inch to the panel to a three or four inch to yet again take pressure off and slow things up?
Lots of info and questions mostly non sensical presentation I'm sure but hope yall can help me out.
