How do you test a lower unit for leaks.
909
If you have a gear oil pump, use the hose on a bicycle pump to add a few PSI to the gearcase and listen/watch for leaks.
if you don't have a gear oil pump, I recommend you get one. It makes adding gear oil much easier than squeezing the silly tubes.
909
Thanks for the idea Chris.
Don't have one yet (only a compression tester) , but will start looking.
I was thinking of using the air compressor in my trunk (for tires) and just spray down the lower unit with soapy water to watch for bubbles.
OK, but not too much pressure, or you will have a leak. Say 5psi max?
Using a compressor is an absolute mistake.-----I use a bicycle pump.-----Gives you proper control of pressure!
tphoyt
I use a brake bleeder/ vacuum gauge and check with both pressure and vacuum. It is possible for a seal to leak in one direction and not the other. Im happy with 10 psi. And I agreed with Racer on the using a compressor. It only take a split second to blow the seal.
Crosbyman
above suggested Danbar video pressure tester works great and not to expensive.
I tested both pressure and vacum on my 75 ETEC GC and small engines from 1950-60s trick is to find the GC fitting to fit the hose and GC
I used this one...comes with the proper adapters
Not hard to make an adapter.----Thread in many domestic gearcases is 3/8--NC ----Piece of 3/8- NC bolt with 1/8th hole.----Brass tee ( modified ? ) for a gauge and shreader valve.---Use JB weld to glue pieces into the brass tee.----Not hard to make something that will work. ----Made my own adapter 40 years ago.
I use my mityvac 8500. it can switch between pressure and vacuum.
Volvo gear boxes have a spec for both pressure and vacuum testing
I believe Merc only has a pressure spec
the kit comes with adapters for most anything:
  • pressure bleeding your brakes
  • pressure testing a cooling system
  • I use the adapter off the gear oil pump to pressure test the gear cases.
