Just Cut out the Kill Switch?
Salmonfishing
I'm replacing the ignition switch and I don't want to maintain the old separate kill switch in the circuit. Can I just cut those two wires coming out of it or would that cause any other problems in the ignition circuit? It just kills the motor right? I don't need anything else killing the motor except for the key! Thanks
is your key switch set up for magneto ignition? yes or no?
tphoyt
Using it can save your life and the life of others.
Not having one can cost you a hefty fine in some states.
In some states you can get fined for not having a working kill switch.
F_R
I personally know of two men that died when getting run over by the boat they fell out of. One of them had only a 5hp motor. Don't think it can't happen to you.
saltchuckmatt
Coast guard just passed a law requiring you to wear one if your boat or motor came with one.
By the way, where do you salmon fish?
dingbat
I never use it and it may need replacement. I may just replace it but checking my options to 'bypass' it.
I do a lot of trolling. Spend probably 60% of a day on the transom checking lines.
Lanyards are useless in this application yet we loose a guy every couple of years out fishing by himself and falls overboard.
Wanted to make sure I was not one of "those" guys.
These work great.
Salmonfishing
I'm fortunate enough to live near the Monterey Bay in California. I'm getting a lot more halibut than salmon last few years mainly because it's easier and more relaxing than chasing salmon in open water. And halibut keeps better than salmon vacuum packed in the freezer!
saltchuckmatt
I'm in Seattle and I fish here and the ocean. I catch salmon but I prefer bottom fish. I run after big lingcods.....aka "toads"
Not to disagree, but salmon last longer in the freezer than bottom fish. The oil in the meat makes it last longer. I try to eat up my hali within 3 months of freezing.
