Low rpm
Beamer50
I have a tracker v14 with cockpit. Just took off 25 hp mercury 2 stroke and hung a 40 hp mercury 2 stroke, only about 5 mph speed increase and 3900 rpms with 17 pitch prop. I just raised the motor 2 inches. Will that help with rpms and speed? I was hoping for 5000 rpms and 35 mph at wot with 17 pitch? Want to run half throttle, saving gas and 25 mph . Have not had boat out since raising 2 inches
Barry
First need to establish the condition of the 40 HP motor.-----To raise RPM you reduce pitch of the prop.----Try a 13" pitch.
Beamer50
Had a 13 , came off a pontoon barge . Lucky to get 19 mph with 13
is your new to you 40hp the same leg length as your old motor?
briangcc
Not sure why you're hung up on using the 17" prop. If its truly running 3900 you're lugging the motor...big time.
For giggles, I ran your combo through Merc's prop selector and took an educated guess on a couple of items. Everything is coming back at starting at a 13" prop.
From what I'm finding on the Tracker V14, 20-25HP is max for that boat. Did you check your capacity tag?
Beamer50
What i meant was this 40 hp came off a pontoon with a 13 pitch prop. I put a new 17 pitch and it should do better than what its doing. No Cavitation. No slipping ???
Barry
Find out what is wrong with the 40.----Post the compression numbers and check for spark.
jimmbo
5mph increase with 15hp increase is actually very good. I suspect you have way too much pitch, which is holding the rpms down
What yr is the 40hp? 2 cylinder?
And everyone is ignoring the pink elephant in the room....
Barry
going up in pitch adds loading
Scott06
Barry
verify the 3900 rpms is correct if so you need to go down in pitch to get rpms up to hit correct WOT rpm range. If you still have the 13" I would try it to see how it reacts.
As far as motor height do you have the cav plate even with bottom of boat? I could see it slowing top speed if it is too deep but I don't think it would affect rpm so much
Beamer50
Sorry, my mother is a short shaft and rated max 40 hp . Just tuned and timed it . Runs great, no cavitation from wot take off ? I've had boats where I use my 19 for pulling skies and my 21 pitch for speed / less gas consumption, Baya spelt wrong, 19 ft.
I've always had 2 props
Beamer50
Also , I would think I'd get cavitation on wot take off like I have before on other boats if to much pitch ? Wouldn't you?
Scott06
Too much pitch doesn’t cause cavitation on holeshot, just causes slow acceleration.
Scott06
Your mother is a short shaft? Not sure what you meant
different boats different pitch is required. Do you know if the gear case ratio is the same between engines?
again is cavitation plate even with bottom of boat ? Then motor is set ok , (maybe not optimized). If you only get 3900 rpm u need to go down in pitch
Beamer50
Motor is short shaft not mother, yes cavitation plate is bottom and center
How can I find out the gear configuration? Model # 0T518996 for the 40 hp mercury max rpm 5500 and 0t935153, 25 hp 6000 max rpm
