Low spark on 2003 25hp
Electric start ?-----How are you testing spark?------Or does spark not jump a gap of 5/16" on a test device ?
99yam40
do you any idea what motor you are talking about?
We sure don't.
Make and model info helps a lot.
but with that said
yes you can test the peak voltage inputs to and out puts of the CDI, and compare them to the specs in your service manual for that motor.
it has procedures and specs
barrie ontario
Ok sorry it’s a Yamaha 25MLHB
First I just used the spark plug on head I never tried a 5/16 gap on a tester but I do have one to try ,
Second comment reply Thank you
I don’t have a service manual I’ll need to source info on
I don’t have access to the motor now it’s up north at cottage but I’m thinking spring lol
Thanks for the replies and advice
barrie ontario
Oh yes no electric start
It is difficult to determine spark quality by using the plugs,-----Harder yet in broad daylight.
barrie ontario
Ok thanks so I will set gap to 5/16 and do it after dark .
I did see faint spark not as much as I see on other gas engines so I was thinking CDI so thankfully I must be wrong
Thanks
99yam40
need to know what peak voltage is going into the CDI and back out.
special meter or regulare meter with a DVA adapter to take readings
barrie ontario
Yes my Alzheimer’s is getting the best of me . I bought a DVA adapter last time I posted n 2013 .
Now I just got to get the values to expect .
I thank you very much
