Mystery hole evinrude 70
maineiac5586
Master Chief Petty Officer
So I am breaking down my 1986 evinrude 70 hp and found this hole. I can see threads in there. It's at the bolt that bolts the cases together. Very confused. I applied air pressure to the hole and don't hear it coming out anywhere. Anybody have a clue what is going on here?
F_R
Busted connecting rod punched through?
maineiac5586
It runs good with great compression and no noise? It's almost like it was drilled too deep when it was made? No air escapes that hole when running and it was dry in the hole no oil or anything
That is absolutely normal.-----It is the bolt hole to hold the block together !-----Once you have this motor apart you will see all this simplicity.
Maybe stick a wee pin in the hole and turn that bolt.-----See what happens.
maineiac5586
I'm sorry I'm not sure what you mean by bolt hole to hold block together or wee pin? Are you being sarcastic or serious?
It is a bolt hole I believe.----One of bolts to hold the block together.---I will leave you alone now.
maineiac5586
No bolt can go into that hole. It is actually at the bottom of the bolt hole from the bolt that goes horizontal seen in last picture. Just seems strange to me
Have you guys seen something like this before?
As stated above many times
The hole is what happens when the drill at the factory drilled thru the casting. The threads are a bit shorter. The bolt is on the other side of the casting split
If it bothers you, shove a bit of bubble gum in the hole, or epoxy, or rtv
I bought 21 of those 3 cylinder motors at auction one time.----So , yes I have seen it on everyone of them.----I assume you are baffled by your first motor ----Sorry to be blunt.
maineiac5586
Lol it's OK. Yes first time seeing this. Thanks for clarification
