Yamaha 30 SG carb emulsion tube
RBoyd1971
Anyone know if this is available? It's the emulsion tube that slides in under the main jet #14. Someone mangled the tubes and main jets. Need the part number for tube/nozzle if available.
RBoyd1971
Did that. Shows part without a reference number. That's how I was able to reference #14 main jet which does.
RBoyd1971
He's a screenshot to show what I mean.
Fun Times
I believe generally what you’re looking for is part of the carburetor base assembly and most likely not going to be found easily but just in case, in your searches, did you click around under “repair kit number 1” as there are some carb repair kits in there too and some come with a few extra parts that you might recognize as the part needed such as number 16 for an example, https://www.crowleymarine.com/yamaha/oem-parts/outboard/1988/30sg/repair-kit-1
