Hvac / thermostat question
Redrig
Master Chief Petty Officer
Hey all ,
I was wondering if there are any hvac folks that can help me out.
I had a new system installed just in April. At that time I just had a standard Honeywell non smart type of thermostat. ( current thermostat uses batteries )
I just got a Google nest "smart" thermostat and was looking at the instructions and how to install am a little confused.
Here is the pic of the furnace board .
My question is mainly ... by looking at this pic , is it possible to tell oif my common wire is currently powered ? The Google nest needs a common wire that is powered.
The system is an amana nat gas furnace and outside ac unit if that matters . I'm just confused by the wiring and don't want to mess anything up.
Here is how the Honeywell is currently hooked up. But again, this one runs off batteries .
Everything works great .
Thanks for any help on the powered wire and wiring question .
Redrig
And I guess the second question would be.
I have a multimeter, how could I confirm if it is indeed powered ?
Redrig
Current honeywell thermostat was installed on previous system though , and in that configuration it had to have batteries. Common wire didn't have power.....
tpenfield
Yup . . . the 'C' wire. . . I went through 2 Nest units until I got that sorted out on my home system (heat only). Supposedly the Nest units will work without the C wire connected, but my results proved otherwise.
I went with Ecobee and put in a 'C' wire adapter.
Not sure why you have your wiring spread across 2 wires, but not really my wheelhouse.
Redrig
You need another wire connected to the C on your HVAC board.
Okay, that makes sense . I will run another thermostat wire , this time a 6 wire .
Bruce, when I do that. Is it simply a matter of adding the extra wire to the "C" on the board . (Does it matter that there is already a wire on it ? I believe for the AC relay)
Thanks again .
Redrig
I went
Good info on the smart thermostats . Did you like the Nest while you had it ?
And I think I have the 2 wires for this.
One group to the thermostat.
Smaller group outside to the ac unit.
But not really my wheelhouse either . I just want a smart thermostat , this current Honeywell is allegedly a decent model but the Temp accuracy i really question at times.
dwco5051
Here is the Honeywell wiring for your original base;
Rc 24VAC power from cooling transformer
R 24VAC power from heating transformer
W Heat relay (stage 1)
W2 Heat relay (stage 2)
Y Compressor contactor (stage 1)
Y2 Compressor contactor (stage 2)
G Fan relay
C 24VAC common. For 2 transformer systems, use common wire form cooling transformer. (optional if batteries are installed)
bruceb58
Thanks again .
Yep...just add to that terminal
Redrig
Outstanding. Running a new wire now as that all makes better sense now.
And I am glad I asked this , looking at current setup. My second heat stage is not hooked up , and it's a 2 stage furnace . So there are a couple bonuses of running a new wire
Thanks everyone
Redrig
Okay , I think I got this knocked out . Ran a new 18/8 wire. Now the wiring is more "standard"
Nest is installed and tests appear to be good. Thanks again 20221217_144626.jpg
bruceb58
Does your Nest support 2 stages of heating and 2 stages of cooling?
Redrig
It does yes. There is a setup part at the beginning and you test each mode/wire.
bruceb58
Awesome...I installed a Nest for someone years ago and it didn't have that feature.
I installed another Nest for a friend last year but he doesn't have 2 stages. They have done a really good job with their setup.
Bob_VT
I put a smart Honeywell in a few years ago and had to run the transformer and C wire because there was no C on the furnace. Merry Christmas STAY WARM!!
