Yamaha 115 4 stroke bad fuel pump canister electrical connector. Need connector. Cant find.
I have a 2008 Yamaha 115 4 stroke. The electrical connector going to the fuel pump canister is loose. Intermittent power going to the fuel pump. I can't buy the connector from the dealer they want over a thousand dollars for a new harness plus I got to get someone to install. To costly for me. It's just the connector shown in the picture. I hope someone can help. Trying to go fishing but I'm afraid to get stranded.
???-----Go wire to wire.----Eliminate this connector.----Or a wee terminal board.
flashback
I need the exact one because the male portion of this connector is mounted into the top of the fuel pump canister. So I need the exact original connector. Is that possible to find?
Gotcha, without any identification marks it won't be easy.. but probably out there somewhere. Maybe you can change the pins.
Perhaps remove fuel pump from the VST.----See what can be done to eliminate this connecter.
boscoe99
