moonrakercat
Thread starter- Joined
- May 11, 2012
- 26
Hi Guys - hoping for some input - I have a 79 thundercraft with a 228 mercruiser i/o engine -I just I swapped the old mc-1 outdrive (lost the gears) for a rebuilt alpha 1 gen 1. My old outdrive had 14.5" 17pitch prop - the alpha one has a 15.5" 18" pitch prop. The boat starts & runs fine - goes into forward gear fine - and drives fine - but if I'm going forward very slowly then put it into reverse - it stalls - I need to quickly restart the engine (when it's in neutral) - then put it in reverse - it works ok then. It does not seem to stall when going into neutral from forward - just when going into reverse directly from going forward - ie when I'm docking. The idle rpm is good at 650 - is this an ignition interrupt switch problem ??(where is this) ? I never had this problem last year with my old outdrive.
I should mention that when I'm at the dock and need to back the boat out into the channel I have no issues - it goes into reverse fine - backs out - then I put it in forward and away we go - it only stalls when being shifted from forward into reverse.
I plan to switch the prop back to the 14.5" and see if it makes a difference - although I don't think it will. And possibly bump the rpm up a bit to see if it helps.
Any ideas / input will be appreciated.
