Rub Rail Aluminum Replacement?
xcursiontri
I am going to replace the rubber around our boat, but I started thinking I might replace the aluminum that holds it as well. The boat was in a slip for years, and definitely shows many scuffs. Is this possible?
jlh3rd
look up taco marine......or google pontoon rub rails
ahicks
Unless it's been really smashed, I'd just replace the insert.
I just want to know that How do you replace a rub rail insert?
at the front or back is a splice plate or end termination trim. remove it
grab the insert with your fingers and pull
take new insert and squeeze between your fingers and push into groove
ahicks
A further hint: set the new rub rail in the sun to allow it to warm up a bit, making it more flexible, easier to insert.
or have it coiled up in a bucket with hot water and dawn dish soap. leave it wet and it just slides in
