- Jul 18, 2011
- 19,595
Greetings,
In follow up to my Axius Joystick Calibration thread (which actually seems fine), I have discovered that the port outdrive has 'delayed' shifting and does not go into gear at idle, but rather takes a but of throttle (1,000 RPM +/-) to engage.
My first order of business is to check the shift linkage/cable adjustment, but I am not sure about checking the adjustment, since most/all published procedures pertain to the manual shifting mechanism.
Is there a special procedure/tools for the DTS ? The shifting is done by an electric actuator rather than cables. I assume the lower part of the linkages (i.e. lower cable) is the same.
If the adjustment proves to be fine, my next step may be to check the cone clutch for glazing. I did the 'poor mans' fix on my previous Bravo drives a couple of years ago.
Not sure if there is a service manual for this (DTS) or not. Any help on this is appreciated.
