67Mirro
Thread starter- Joined
- Apr 13, 2022
- 41
Ok, I’ve been fighting a problem with my boat for quite some time and think everything has made sense to me after using it this past weekend just want to know from all you guys if this would make sense to you. I’ll explain it all and let me know if that’s what you think it is.
So I first took my boat out in the spring and it was running fine but then When I would get on plane the boat would be going fine then all of a sudden slow down but the rpm’s would still stay high until I let off the throttle on the tiller. And then I would rev back up and go and another 30 seconds would do it again or it would catch it self and take off again. I initially thought it was the fuel pump and fuel delivery so I changed it all and rebuilt the pump then went back out. I went back out and started doing the same thing again so it had me stumped. Then this past weekend I took it out ran fine on plane for 5 minutes then kicked down and rpm’s stayed high while my speed went down to 4mph and if I went to accelerate it would rev up but not go any faster than 7mph but would rev up high and sound normal just would not grab the water and go and after that it was like in limp mode and would only got 5mph no matter how much throttle I gave it it would just rev higher(kind of like when a clutch is slipping in a car) . After doing some online research I came to realize that maybe my prop had spun on the hub? And leading up to my boat finally shutting down for good made me think was it failing before when it would do it occasionally and it would slip here and there and then this week I did it in and finally wrecked the bushing in there? Has anyone had this issue before? Thanks in advance, just going down to the lake next weekend and want to try to get this resolved.
