nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,086
This one showed up in a Google Search. Might be different material/length though but gives you an idea...
https://www.ebay.com/itm/1143869546...ay too much other stuff to do on this boat...
That's what I've been calling it. I don't think it needs to be exact, just close enough. Given how common that piece was, I'm surprised that no one makes a generic.I would call it a bow end cap for the rub rail. Probably like finding a needle in a haystack given the variety of bow profiles.
Actually, this might be an idea. Maybe a little metal repair epoxy would do the trickI bet if you find a good aluminum welder he could fill that in. On my first (and only) total boat and outboard overhaul project 22 Years ago I bought a 70 h.p. 3 cylinder Johnson outboard where the center cylinder connecting rod decided to make a hole in the engine block. Never new it was possible, but a guy told me to take it to this certain place and he'll weld that up.
So I brought it to the guy, came back in a few hours and I literally couldn't even tell there used to be a hole in the block.
That's right up my alley! JB would do it. Ain't no stress on the part unless you run into something..Actually, this might be an idea. Maybe a little metal repair epoxy would do the trick
