PosessionSound26PC
- Sep 21, 2020
- 78
I have a 1989 Formula 26PC w/ twin Merc 4.3 and Alpha I's. Long story short: starboard engine froze up, shop where I store boat said new motor needed, buddies and I decided to do it ourselves w/ rebuilt motor so prepped by tearing stuff off (exhaust, electrical, etc), decided to look for the "problem" while tearing stuff off and before buying new motor, pulled heads and found nothing, pulled outdrive and both motor and outdrive turned just fine but not when together! Turns out the shop couldn't be bothered to check the gimbal bearing - seized up solidly. I replaced that, replaced exhaust components, repainted intake and heads, etc. Got everything back together.
Went to start it - dead batteries due to my ignorance about needing to keep deep cycle batteries charged/topped off. Bought new deep cycle batteries and installed. Blowers work, lights work, all accessories work. But when starting either motor (including port which I never touched in any way), nothing happens except a clicking noise at what I determined were the Starter Slave Solenoids mounted on the same bracket as the Mercathode systems and the 50amp engine circuit breakers (one each on both motors). Both solenoids make a clicking noise but nothing happens thereafter - no starter movement or noise.
I didn't have a volt meter with me so couldn't check if battery voltage dropped below 12V when ignition switched is turned but assume batteries are good as they are brand new!? What else could it be? The boat has been sitting for two years, covered. I assume the starters are sealed units and unlikely to corrode? Weird that port motor won't turn over either - makes me suspect batteries or some other common component but don't know where to look. Any trouble shooting hints besides voltage check while turning key? Much appreciated.
Edit: when turning the key for starboard, boat voltage indicator pegged at 16V (max). When turning key for port, voltage meter read something like 11V. Mean anything? I double checked that both my batteries were wired properly (black to black, red to red...).
