- Jul 23, 2011
- 52,034
Depends where you have the cam set and where the timing is.With a mild cam what vacuum reading would you expect?
15 to 18 inches of mercury is where I would expect at 0 up at idle with 8 BTDC base timing
Bring the base timing up to 10-12 BTDC and you will bring the idle vacuum up.
Did you get a fuel pressure reading while under load?
