Dave French
Thread starter- Joined
- Jun 23, 2022
- 4
I have a 2013 8.2 and I am getting a repeated guardian code 328 which is for low sea water pressure. I have replaced the raw water impeller (turned out the old one looked fine) and installed a new pressure sender. I am getting around 5 or 6 psi when cruising. I have a Rinda tech tool and when I look at the freeze frame data for the fault the pressure is normal but I do see a bizarre trim position reading recorded in the data set of 278% which is impossible. It reads normally in live data mode. I’m wondering if I am getting a bad trim position reading which makes the computer think the drive is up in the air and therefore receiving no water at the intake. This is definitely not actually happening. Help!
