'Hot' wire location
tengals123
Master Chief Petty Officer
Where can I find a hot wire location, not in the control box. I don't want a wire hanging out of the control box?<br /><br />cheers
Dunaruna
Re: 'Hot' wire location
What's it for? What will it power?<br /><br />You got mail.<br /><br /><br />Aldo
tengals123
thanks for the reply aldo. It's for the gauges. <br />you got mail too.<br />cheers
Dunaruna
You have a choice of two circuits, battery hot and ignition hot. Personally I prefer to wire gauges battery hot (through appropriate protection). It's a simple matter of running a 6 - 8 mm wire from the battery to the a switch panel, the heavy wire is overkill just for gauges but it will allow you to add more electrical devices in the future.<br /><br />If you choose ignition hot then you'll need to post in the merc section and find out which color wire in the control box is the correct one.<br /><br />Aldo
tengals123
i'll need to run it to ignition 'hot' so that the gauges will come on when the key is turned 'on'. The lights i will hook up to my nav. lights.<br /><br />cheers
