ronnieverette
Thread starter- Joined
- Jun 8, 2010
- 13
1984 Welcraft Nova 23 / Mercruiser 260 / Alpha one gen1.
After replacing the entire out drive and the lower shift cable I have run into a strange occurrence. The thing will shift into forward (counter clockwise on the prop) and reverse (clockwise on the prop) when it is tilted up for trailering. When I lower the unit into a drive position, she will not go into forward, but will go into reverse. How is it that the "Throw" on the lower shift cable would change depending on where the tilt / trim is at any given time? More importantly, what or where does this indicate an error on my part?
Yes, it was in forward when I installed the outdrives. (bolted together and quite heavy I might add)
Yes, I had a friend hold the prop in the forward gear when I measured the brass barrel to plastic eyelet on the shift cable (adjusted to exactly 6inches)
FYI the outdrives are SEI Marine SE-106.
