Radio not working
Bwbw
Say I had my ignition switched replaced now radio not working. Any help
mike_i
Get a voltmeter and start tracing the 12 volts from the fuse box thru the switch to the radio. First check the fuse.
Bwbw
Thanks I did put in new fuse. Could it be the way new ignition switch was installed ?
mike_i
"Could it be the way new ignition switch was installed ?"
Most likly it is the issue but by not seeing it I would be guessing. It shoud be easy to find the problem with the voltmeter.
