Volvo 3.0 GSP-C carb jets
mcallan1972
Hello all.
Would anybody have the carb specs on 2003 volvo 3.0 GSP-C with holley carb 80316-3? The main jets were so dirty I didn't realize that the two jets were different and now can't find any info on what one goes in port side and what goes in starboard side of mixing block and dealer is not being helpful. From what I have found is that when the two are different it seems the smaller is on the starboard side.
Thank you to all in advance.
jimmbo
Your carb is a 500cfm model
In my VP Service manual I did find one 500cfm Holley 2300 that used two different Main jets(all the other carbs used the same jetting on both sides) but it only lists the VP Part#
Volvo Penta #3863240 500 CFM Model 2300-2V
Pump Lever Clearance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.010-0.015 in. (0,254-0,381 mm)
Choke Unloader . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .0.300 in. (7,62 mm) Measured Lower Edge of Plate
Choke Setting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Notches Lean
Initial Idle Mixture Setting1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . . . . . . . . . 3/4 Turn Off Seat
Main Jet - Port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 72
Main Jet - Starboard. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 71.1
Power Valve . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . . . . . . . . . 2.5
Float Setting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Parallel to Fuel Bowl When Bowl Inverted
Choke Vacuum Qualification . . . . . . . . . . . . . . . . . . . . 0.365 in. (9,3 mm) Measured At Lower Edge of Plate
Pump Cam Position (blue cam) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . No. 2 Hole of Cam and Throttle Arm
mcallan1972
I did see this on this forum possibly your posting from years ago. I also have 2.5 power valve but 67 and 68 jets. My carb VP part number is 3857981. I may have to put the smaller jet in the primary starboard side and start from there. This carb for sure has never been apart before, unless they sent back to volvo to have it re-painted red. Thank you for all your help folks.
Lou C
just click "specifications"
mcallan1972
Ya I found that on Holley's website too but not the specs I'm looking for.
