Tin Rig Tow Vehicle
LMBguy05
Looking to buy a 17' aluminum fishing boat. Best guess is I'll end up towing between 2,000-2,500# total. Single axle trailer from manufacturer does not have brakes. It's not even a factory option.
Curious what those of you pulling similar weight with an unbraked trailer are using safely and successfully?
Check towing capacity. Most vehicles require trailer brakes for weights above 1000 or 2000# unless you get into a truck or full sized SUV
Alumarine
As Scott says, also some jurisdictions require brakes over a certain weight.
briangcc
Uncle tows his Sylvan with an AWD Traverse.
Cousin tows his Sylvan with an AWD Highlander.
Both are sitting on roller trailers, single axle, no brakes - standard 4 pin wiring plugs.
IF it were me, I'd be looking at mid sized SUV - Durango (with tow package), Pathfinder, 4Runner, Highlander, Pilot (requires dealer installed cooling package), Traverse OR mid sized pickup - Ranger, Tacoma, Frontier, Colorado, Canyon.
You *might* get away with an older V6 Sienna (tows 3500) or Chrysler Pacifica (think this is in the 3500 class).
Here is a list of SUVs with 5000# towing or more
Make/ModelEngineMax. Towing Cap.Starting Price*
Acura MDX3.5L V65,000 lbs. (SH-AWD)$51,272 (SH-AWD)
Audi Q7 (55 TFSI)3.0L Turbo V67,700 lbs.$63,945 (Premium 55 TFSI)
Audi SQ74.0L Twin-Turbo V87,700 lbs.$89,840 (Premium Plus)
Audi Q83.0L Turbo V67,700 lbs.$72,145 (Premium)
Audi SQ84.0L Twin-Turbo V87,700 lbs.$94,395 (Premium Plus)
Audi RS Q84.0L Twin-Turbo V87,700 lbs.
$121,745​
BMW X53.0L Turbo I67,200 lbs.$59,950 (sDrive40i)
BMW X63.0L Turbo I67,200 lbs.$67,900 (xDrive40i)
Buick Enclave3.6L V65,000 lbs.$46,640 (Essence AWD)
Chevrolet Traverse3.6L V65,000 lbs.$36,895 (LS AWD)
Dodge Durango3.6L V6/5.7L V8/6.4L V8/6,200+ lbs.$35,752 (SXT, ’21)
6.2L S/C V8(Tow N Go/392/Hellcat: 8,700)
Ford Explorer2.3L I-4/3.3L V6 Hybrid/5,300 lbs.$34,715 (Base, ’21)
3.0L Turbo V6(Hybrid: 5,000/ST: 5,600)
Honda Passport3.5L V65,000 lbs.$36,399 (Sport AWD)
Honda Pilot3.5.L V65,000 lbs.$42,669 (EX-L AWD)
Hyundai Palisade3.8L V65,000 lbs.$36,510 (SE AWD)
Infiniti QX603.5L V65,000 lbs.$47,875 (Pure AWD)
(Sensory AWD/Autograph: 6,000)
Jeep Grand Cherokee3.6L V6/5.7L V8/6,200 lbs.TBA (2022 MY pricing
2.0L Turbo Hybrid(5.7L: 7,200/4xe: 6,000)not yet released)
Jeep Grand Cherokee L3.6L V6/5.7L V86,200 lbs.$41,425 (Laredo 4×2)
(5.7L: 7,200)
Kia Telluride3.8L V65,000 lbs.$34,490 (LX)
Land Rover Defender2.0L I-4/3.0L I-67,716 lbs.$52,525 (Base 110)
Land Rover Discovery2.0L I-46,613 lbs.$55,925 (S P300)
LR Range Rover3.0L I67,716 lbs.$94,050 (Range Rover P360)
LR Range Rover Sport3.0L I67,716 lbs.$71,550 (SE P360)
Mercedes-Benz GLE-Class2.0L Turbo I47,700 lbs.$58,875 (GLE 350 4MATIC)
Nissan Pathfinder3.5L V66,000 lbs.$37,160 (S 4WD)
Porsche Cayenne3.0L Turbo V67,700 lbs.$71,010 (Cayenne)
Rivian R1SElectric7,700 lbs.$70,000 (Explore Package)
Subaru Ascent2.4L Turbo H45,000 lbs.$33,970 (Base)
Tesla Model XElectric5,000 lbs.$99,990 (Long Range)
Toyota 4Runner4.0L V65,000 lbs.$38,020 (SR5 2WD)
Toyota Highlander3.5L V65,000 lbs.$38,599 (L V6 AWD)
Volkswagen Atlas3.6L V65,000 lbs.$42,490 (SE V6 w/ Tech, 4Motion)
Volkswagen Atlas Cross Sport3.6L V65,000 lbs.$42,185 (SE V6 w/ Tech, 4Motion)
Volvo XC902.0L Turbo I45,000 lbs.$54,965 (T5 Momentum AWD)
roscoe
Dodge Grand Caravan 2011-2020 tows 3500#, but says you need brakes if over 1500#. And trust me, you WILL want them.
I made one trip, traveling through a small town along the lake shore. Coming down a hill at 25 mph and could not stop.
Ordered up a set of brakes when I got home.
The best $600 I spent in a long time.
You won't find a trailer rated for under 3000# that has brakes.
But many have the flanges on the axle so brakes can be added.
So check out the trailer on the rig you want to buy, and see if the dealer will install brakes for you.
Or install them yourself.
that is where the term "stand on the brakes" comes from. when you put both feet on the brake pedal and pull yourself off the seat trying to get more brake pressure.
BrettNC
Any v6 and a lot of 4 cyls will get it done if towing locally.
Sprig
What are you planning to tow with? Doesn’t really matter what we are towing with, need to know what you plan to tow with.
jimmbo
I tow with Cars
Buick has a 5000 lb Factory Tow Option
Cadillac has a 7000 lb Factory Tow Option
TechSgt
Ive got a 2012 Dodge Durango with the 3.6L and have towed 4400 no brakes and it did fine, just leave extra space for the extra stopping distance.
JimS123
I tow with Cars
OMG, you must be the only guy left. (except for me)
One day I pulled the boat into the ramp and got in the car. A bunch of millennials came over and said they were waiting to see what that old car could possibly pull. One minute of winching and the rig was in the lot. They shut up quick.
jimmbo
That looks like a Pontiac. I doubt it's Tow Rating is for more than 1000lbs.
My Buick and Cadillac came from the Factory with the Towing Option, with Heavy Duty Suspension, Heavy Duty Brakes, Larger Capacity Cooling System with Mechanical and Electric Fans, Two Transmission Coolers, Modified Transmission and Shift Programing, and Larger Rear Axle Assembly. The Cadillac even came with a 5 Connector Wiring Harness already wired, and stored in a pouch between the Rear Fender and Trunk Liner. Both Cars have the Second Gen LT1, and are capable of towing at speeds well above 75mph.
A lot of clowns don't realize that a few decades back, most tow vehicles were cars. And the Trucks of the Day were a more realistic size than the Hideous things sold today. I have launched and retrieved my boat from gravel and dirt ramps that had 4x4s digging themselves stuck.
JimS123
It's a 1980 Bonneville. It is equipped with the factory towing package with most of the things you itemized. Factory specs list a 4500# towing capacity with the package.
Scott06
You two aren't the only guys left...
used to tow my dads 22 ft Catalina swing keel and my sea ray 170 with a honda accord coupe ... Also used a Volvo 240 wagon and a Taurus over the years ...
JimS123
My first towcar was a 1961 Mercury Comet with a 144 cid 85 HP inline 6, 3 on the tree. The boat was only about maybe 1000#. Never had an issue with it.
jimmbo
I wasn't aware of Pontiac offing a Tow Package Option, of course I will admit to not knowing much about any Pontiac. I know a lot about Olds, Buick, and Cadillac, mainly because those are the Brands I have owned, 2 Olds, 3 Buicks, and 5 Cadillacs. Current ownership, licensed, insured and on the road, are 1 Buick, and 2 Cadillacs
JimS123
It's a 1968 Lark Selectric. Most troublesome motor I ever owned. Traded it in on a Triumph and had similar shifting problems. Finally sold that one for a Johnson Stinger. THAT was the best 2-stroke I ever owned.
