- Jul 18, 2011
- 19,536
As if I did not already have enough things to do with my new-2-me boat, I noticed a oil spot below the port outdrive this weekend.
Following it up to the outdrive . . .
. . . and then upward . . .
It looks to be dripping from the oil line. I also noticed a trace of oil seepage around where the bell housing meets the outdrive in the area of the oil interface valve.
So, it looks like I'll have to take things apart to investigate further.
I am wondering if the oil check valve got damaged when the outdrives were last serviced/installed and if that is causing seepage both down the oil line and around the area of the valve.
The oil line (hose) looks dry as it leads up to the transom assembly fitting . . .
Any thoughts, guidance, or similar experiences are welcome
