Boat wont turn over…Safety Switch?
I just got an old Stingray SVB 165 SS with a 120 Mercruiser motor. I threw a good battery in it….and it does nothing. Fuses on the dash are good. I don’t know anything about it. Is there some type of safety preventing it from turning over? I should at least hear the starter clunk….or something. Help me please.
Thanks in advance!
j cat
Thanks in advance!
remove the lower out drive ... remove the spark plugs ..then crank the engine . see if water is in the bellows/cylinders.
what is your 120 merc year .?
Buzzsaw420
Battery is a good start now start following every wire to their connections and cleaning them up all the way to the ignition.
achris
More fish than mountain goat
Again, too invasive, too quickly. Plenty of checks to do before pulling things apart.
First up, turn the key ON, do the instruments come on?
If so, use a multimeter or test light and check for voltage at the ignition coil+
Then get a helper, and with the gear shift in neutral, turn the key to START and check voltage at the starter slave solenoid.
You can also put a remote starter switch on and see if that turns the engine over.
Yes, a lot of diagnostics to do before pulling drives off.🤦‍♂️
Chris.......
j cat
Chris.......
HE BOUGHT IT NOW !
Scott06
Chris.......
Yep, if you hear the starter engage and click then look at engine/gimbal/ujoints/drive being locked up, but thats not whats happening here
Thank you everyone for the help…so quickly too!! it turned out that the starter was froze up. It has been setting for a few years. I am sure there will be other issues…..
Thanks again!
@j cat
how could you come to this conclusion
from this information
Thanks in advance!
since there was no movement or clunk from the starter. this would normally be dirty connections, bad key switch, bad cables, bad battery, bad starter solenoid or bad starter. all external to the motor and all diagnosable with a multi-meter and test light
so why are you suggesting removing the lower out drive and spark plugs?
or arguing with @achris who is a certified mercruiser mechanic and used to be a mercruiser dealer
Just wondering, as your diagnostic comments over the past few weeks have me believing you get your bad diagnostic information from youtube
j cat
Thanks again!
when the engine does not start the starter motor locks up because the engine does not go in the reverse direction ..
when the engine starts up then the starter motor does not lock up ..
take the starter motor out and see if it runs .. then rotate the engine in the correct rotation if the engine rotates.
achris
I think the original poster is saying the starter motor was seized from a lack of use, not that it was locked in the ring gear.
Oh, and one thing. The engine doesn't go in reverse when it starts. The starter motor gets thrown out of mesh by the flywheel going faster than it (if the key isn't released before that actually happens)...
Chris...
the OP already posted that his starter was seized/rusted up from sitting
