Lou C
- Nov 10, 2002
- 12,979
Depending on how much tolerance you have for more hydro locks you could just change one thing at a time to answer the question what was the cause. So if the flapper solves it totally you know it was back wash/stern of boat too low if not then it’s solved with adding the vacuum break valves you’ll know it was exhaust reversion. There was a vid someone put up on you tube with clear plastic hoses so you could see what reversion actually looks like. This is why marine inboards cannot have radical cams with lots of valve overlap.
