- Mar 8, 2009
- 44,540
Never found oneIs there a flow chart for troubleshooting like for the TB systems (or points)? Any reason that you can't simulate a pulse from the dizzy pickup to the module to test?
I think this is out of a VP manual but outlines how to narrow it down https://f01.justanswer.com/oldnewenglandmarine/deacd8eb-a4ca-4db4-9bec-6e9bb71197e7_Delco_EST.pdfIs there a flow chart for troubleshooting like for the TB systems (or points)? Any reason that you can't simulate a pulse from the dizzy pickup to the module to test?
I'd disconnect it at the coil, just to eliminate a wiring issue between the coil and dashMy tach is also entirely disconnected at the dash.
YesWould I simply disconnect the shift interrupt wire from the terminal post?
Thank you, on my coil there is a plug with the purple power wire and the grey which I understand to be the tach/shift interrupt wire. I am not sure how I would disconnect the tach at the coil without also disconnecting the purple power wireI'd disconnect it at the coil, just to eliminate a wiring issue between the coil and dash
Yes
With looking at both connectors on the dizzy, remove the one on the right. This is used for base timing and also for shift interruptWould I simply disconnect the shift interrupt wire from the terminal post?
As long as you got a good connection when sticking in terminals b,c,f meter probes may be too fat to get a good connection to the blade terminal inside of there.I just tested my ignition coil and did not get any resistance readings at all on steps 3, 4, 5. Does this sound likely? I am almost positive my meter is fine, as I was getting readings when testing the pickup coil. If so, I will order a new ignition coil
This is what I was concerned about. Don't want to go jamming the probes in, but can't tell if I am getting a good connection or notAs long as you got a good connection when sticking in terminals b,c,f meter probes may be too fat to get a good connection to the blade terminal inside of there.
I would verify that since you have 3 tests not getting any ohms , also I assume coil isn't shorted to ground? You didn't mention thatThis is what I was concerned about. Don't want to go jamming the probes in, but can't tell if I am getting a good connection or not
Maybe your meter is not good. Previous test on dizzy coil showed it was badI just tested my ignition coil and did not get any resistance readings at all on steps 3, 4, 5. Does this sound likely? I am almost positive my meter is fine, as I was getting readings when testing the pickup coil. If so, I will order a new ignition coil
I have not added a direct ground to the coil if that is what you mean, no.I would verify that since you have 3 tests not getting any ohms , also I assume coil isn't shorted to ground? You didn't mention that
I did get a lower resistance reading on the new coil. It was hovering around 60Ohm vs the 200Ohm of the previous coil doing the same test. I will try the small pieces of wire and see if I can get any reading that way.Maybe your meter is not good. Previous test on dizzy coil showed it was bad
Use some small pieces of wire to put inside points
I'm not sure if you are using what alldodge posted in post # 21 or the link I sent .I have not added a direct ground to the coil if that is what you mean, no.
Id spend $30 on a digital mutli meter vs a coilI just retested the ign coil with some wires sticking in and that definitely worked better. I fear my multimeter although is working may not be good enough to give me the accuracy I need. Here is a photo of it. On steps 3 and 4 on setting 10x, the needle shot all the way to the right. I don't have a 1x setting. When testing step 2, on either x1000 or x10, I cannot notice the needle moving at all, which seems to be on or close to the infinity mark. When testing step 5 using x10, the needle was hovering around the 4-5 mark on the green Ohms scale. I know I can't rely on these as I don't have the proper x1 and x100 scale on my meter. I may bite the bullet and replace the ignition coil regardless. Thoughts?
