NPT fitting question
ptbrakefield
This is on a pontoon boat, but it's not really a pontoon question.
The plastic plugs in my pontoon have disintegrated. I need to replace them. However, I'm not sure what size NPT plug I need.
How do you measure for the correct size? From the outside, or inside where the taper is narrower?
Ayuh,..... It's probably 1/2" pipe,..... very common,......
The other possibility is 3/4" pipe,....
The Od is 'bout 1/4" larger than the actual size,......
1960 Starflite
