Steering wheel shaking
Votetrump
I have a 2002 stingray with a 4.3 inboard, we took the boat to the lake, put it in the water , I started out into the lake and the steering wheel was give me the death shake. What could cause this ?
When you say inboard, you really mean I/O right? If so, I would suggest the power steering system has an issue. Is the fluid level correct? Does the PS pump turn smoothly when the engine is running?
Votetrump
The PS pump does turn smoothly if I go in Idle speed, but once I throttle down the steering wheel shakes bad.
Grub54891
Is it firing on all cylinders? If it's not, the entire boat may shake hard under low power.
Tell us more.----Did it run fine last season ?-----Hit something ?----Bent propeller ?----Bent propshaft ?
QBhoy
Hi. Does it do this in neutral with revs or just in gear ? A bent prop could cause this for sure. Many other drivetrain related things too.
