1976 Johnson 115 electric help
tux16090
I am looking for a bit of info for a 76 Johnson 115 outboard. I have posted about this before, but that was a while back and slightly different questions. At that point it was not running, but now it does run. My questions are as follows.
1. What battery do I need for this engine and is my starter bad? I hear around 500-600 CCA, but when I try to start the engine it needs way more than that. My truck has a 700 or 730CCA battery, and it took it running at 2200 RPM to crank the engine with 2 plugs in (was checking spark at the time). With 4 plugs it takes a running diesel truck (2 730CCA batteries) to crank and fire. Maybe it is my jumper cables at 20ft (4AWG), but that still seems a bit much for a 115. I hook up strait to the starter, so I don't know how that would be different from running a 1500CCA battery.
2. What is the charging capability of the engine? From what I understand it is 6A as there is not proper alternator, but I just want confirmation. I would like to run a small stereo on the boat, but I don't know if that is possible with such little amperage to charge the battery and run radio. I am not an expert in this field, but it looks to me like you can run speakers strait off of a head unit without an amp. If that's the case, could I do that, or would that overwhelm the limited power?
3. If my starter is bad and I lack power, could I switch to a starter generator, or would it be better to try and replace the starter and add an alternator? I do not know much about this, if I hadn't made that clear by this point
4. Is there a wiring diagram for this engine? I would like to know where all the wires tie back without having to tear it all apart and/or guess as to what they do. I think I figured out the key pinout, but I am not entirely sure.
5. Is there a way to test the temperature sensors, and a replacement horn for the control center?
6. This is getting a bit less electric related, but still questions I need answered. Is there a specific throttle cable I need for this engine, or is a generic Johnson/Evinrude/OMC throttle cable good enough? The plastic bits that connect on the engine broke on my cables. That's near 50Y/O plastic for you.
7. There is a linkage that attaches to the throttle on the engine, and goes up under the flywheel. Is this a timing advance, or something else?
8. While trying to run this engine, I was having trouble getting water up into the water pump using muffs. Maybe it was a lack of water as I did not turn the hose all the way on to try and save water, or a lack of pressure as the muffs are not sealing really great. I was going to run it in a large bucket of water so it is filled to the point of the pump and a bit more, but I just wanted to know if this engine need a lot of water to push through the pump and if I am on the right track.
I really appreciate any information, even if it only answers 1 question. Thank you
Buckischloo
There is a different forum here for Johnson and Evinrude motors. You may get more help there.
Post the results of a compression test first.-----I would take the starter apart for inspection.-----This will establish the condition.-----My guess is that it is bad.----Easy to take starter apart if you are interested in learning a bit about them.
tux16090
I will probably just get a new starter. I opened it up and the brushes are worn, and the insulation on the coil looks questionable. I'm sure I could fix it if all the parts for it were available (they are not anymore), but I don't know what the problem is exactly and I don't want to throw money at it to find out it still does not work right. As for a compression test, I went to start it again (before removing the starter), and it wouldn't crank fast enough to start. I know its got decent compression, but that will have to wait at this point as I pulled the engine off of the boat to split the hull.
Crosbyman
have you looked into a rebuild.. .some electric motor repair shops may help $ vs $$$ of a new one.
Best to wait until the boat is repaired / refurbished.------Owner may have the funds saved by then to repair / inspect the motor.-----May even have the funds to buy a newer motor by then.
tux16090
I am trying to do a restore, so I want to keep the boat and engine I have. When I have the hull fixed (replacing floor and now the transom too), I will put the engine back on and finish the job. Hopefully it is just the starter and main power wires at this point. I already rebuild the lower unit and got new head gaskets, bolts, cleaned and rebuilt the carbs. As for the starter, I looked into it and if it is just the brushes, that's $20-30 and the only armature I found is $27 used. Best case its about $50 to rebuild (assuming that's the issues), I can get a used one for $30-40, or a new one for $120ish. I have plenty of time to decide, as I don't think this restore is happening before the end of this year, but I hope it does. It depends on how sick of it I get in the summer, and where I want to put my money.
My other questions still stand. Number 1 is no longer relevant, and number 8 is not entirely relevant right now, as I will just submerge the lower unit when running it now. Thank you for the replies.
Wiring diagram can be found online, yes it is there..----A stator upgrade kit was available as an accessory item.----Yes that linkage advances the timing.
Best to finish the boat first.----Save the beer tokens till boat is done.-----The motor work is easy.
I think those wiring diagrams clearly show where each wire comes from and what item it connect to !
Crosbyman
It's better than nothing. I was hoping for one that would say what each wire is for. IE (this may be wrong) Purple=12V switched; Red=12V constant.
the diagram is self explanatory...
a solid wire goes a-b
a switched wire goes a... switch...b
the source (A) and the end (B) tells you what it is for and what to expect
