- Jul 18, 2011
- 19,489
Greetings,
Pre-season prep work is just around the corner and I am reviewing the closed cooling systems on my new-fangled Mercruiser engines. (2016 6.2 SeaCore models S/N' in my signature)
1) These engines have a 'poppet' valve, which are a new 'thing' to me. I believe poppet valves are more common with large outboard engines. Anyway, my understanding is that the valve releases at higher engine speeds (based on raw water pressure) allowing more raw water to go directly to the exhaust. At idle speeds the valve is closed and the exhaust gets raw water after it has gone through the raw water side of the cooling system.
Is my understanding correct? My previous boat had the old-school big blocks and the cooling system was more basic. . . . water flow to the exhaust was not regulated.
Another question/issue . . .
2) There was (and is) some coolant lost on the port engine . . . I noticed it last year after a 6 hour run and then again over the winter. It is loosing about 12 oz of coolant, and needs to be topped off. My plan is to check for leaks and do a pressure test if nothing obvious is found. The cooling systems on the new engines seems to be a lot more complex than the older engines. There is a 'crossover' assembly and I'm not sure what that does ??? It seems like a new 'thing' as well.
TIA
TIA
