Where can i get a new controls and harness for a 71 selectric shft
Jmusick
My harness and controls are a mess i dont think there salvageable just so many splices and repairs to the line i think its just too far gone. Is there somewhere that makes reproduction parts? Ive had bo luck on ebay or sourcing one used locally. If someone could help me out would be amazing
Does your motor run?----Results of a compression test ?-------That black rubber plug is just a " convenience / time saver " feature.-----You could eliminate that with a terminal strip.-----If in Canada-----evinrudeparts.ca
Jmusick
Compression is good. Its new to me i myself have not had ot run. For the terminal strip does it match colour to colour or will i need to find the diagram to match everything up
Jmusick
Ok so terminal block worked sort of. It turns over now but.... New issue. It turns over without the key? As soon as i touch battery to the cable, starter engaged. Do i have something crossed in the control side in the key wireing maybe
Crosbyman
1- key defective
2- wiring mixed up/crossed
3-selenoid stuck (defective)
assuming... condition #3 is not the issue
you need to check the selenoid control post for a +12V ONLY when key is in START otherwise backtrace to find out why
see diagram provided for BASIC layouts
fused +12v purple white to switch BATT post then white S post to selenoid during START only
Jmusick
1- key defective
assume condition #3 in not the issue
I have a feeling its #2 as ive tried another selenoid
Jmusick
Thanks everyone. Got it turning over great now. Couldn't have dun it without the help
Crosbyman
and.... where was the problem ..exactly so we can cheer and share your good work ??? :)
Jmusick
Connector from controler to motor was bad so after i rewired everything to a terminal block (and fixed the backwards wires at the ignition) and all was good
