Compression Numbers - 1986 Evinrude 110 HP
clm1117
Left side top - 100
Left side bottom - 95
Right side top - 115
Right side bottom - 115
Motor has been sitting up for a number of years. Compression test done with throttle wide open but motor is cold because I didn't want it to start. I'm determining whether to spend the money to take it to a mechanic to get it running again.
So with those numbers what are your thoughts? Trash or treasure?
Pull the left side head off.-----I think you have broken piston rings.-----Every one of the v-4 crossflow motors will suffer from that sickness.
clm1117
Is it easy for a backyard mechanic to replace the rings? I've got the manuals. I'm guessing if the rings are broken they could have done other damage?
You likely need 4 new O/S pistons and rings.------No point putting new rings on old pistons.------With a manual and some wrenching ability you can do this.-----Start by pulling that head off for inspection.-----I like pictures.-----Maybe it just needs new head gasket.
clm1117
Sounds good and reasonable. I have the OMC Service Manual. I'll pull the head off and post some pics. Maybe I'll get lucky and it's just the head gasket. More to come. Thanks.
