A mercruiser 4.3l MPI with a low weak idle hard to start
samseoane
Hello Everyone,
I have A mercruiser 4.3l MPI with a low idle between 450 and 500. Here’s what I done so far.
2008 engine no alarms no beeps
1New Fuel Filter
2 New IAC and cleaning of the throttle area
3 fuel regulator on top with fuel rail checked for blockage no issues
4 new spark plug wires and spark plugs.
Took off all the spark plugs and checked
Compression all cylinders 120
5 checked for spark on all 6 holes of rotor cap with timing light no issues
6 fuel rail psi 40.
7 Diagnostic computer connected no Faults.
8 Duty Cycle on IAC as seen by computer stays on at 99% all the time (NEW IAC NO HELP)
Your compression is way too low and your fuel pressure is low
Your compression should be between 140 to 150 or more. Check your gauges
Your fuel pressure should be 43psi minimum.
alldodge
With the IAC at 99% the ECM is trying to increase the rpm.
Your compression is low if you gauge is accurate
What does the MAP and Temp show?
Does it get better when the motor warms up or stay the same?
vroom ZOOM
Just a thought... do these motors have an IAC bypass adjustment that could be clogged?
QBhoy
Assuming your gauge is off. You’re missing the main cause of this on the mpi. The famous diz cap !
samseoane
Hello Everyone was off the boat for a while. The compression and fuel pressure are good. im showing 140 and 43 for fuel
samseoane
i accelerated engine here a little bit to try to match other one at 600 RPM. Here it shows the IAC at 99% and Water pressure sensor 0 PSI. Both replaced REFERENCE ATTACHED
samseoane
Hey motor stays the same always surging low idle . I Attached a pic at the end of the thread showing the motor
alldodge
140 is better but not great
What is the deviation of the compression numbers?
When idle is below 400 rpm the ALT voltage is low, temp is cold and MAP is where it should be "IF" readings are correct
When MAP shows 9 psi the voltage should read about 2.8V
At 8 psi reading should be about 2.3V
There might be a vacuum leak
achris
More fish than mountain goat
Somewhere along the head/manifold gasket. Use a bit of carb cleaner and spray in the suspect area. When the engine revs change, you found the spot.
Chris.......
alldodge
Can spray wd40 around the intake and throttle body to see if ram changes.
samseoane
thanks for all the help guys a little dark here in south Florida but will definitely hit it tomorrow
samseoane
Fixed the sea water pump pressure sensor. Sprayed starting fluid around intake manifold and no luck on any RPM changes. Idle stays very low
alldodge
What fixed the seawater sensor?
What is the motor serial number?
Might be the Throttle body factory adjustment has moved. Look close at the stop screw and see if it has been moved
samseoane
I pulled off the connector and noticed it has the green salt buildup did a contact cleaner with a toothbrush. The SN is ia309885
alldodge
Think that is another puzzle is with the water pressure showing zero the available power should be less then 100%. Also I would expect to see guardian mode active
