Force 9.9HP 1991 outboard
Boatguy32
I purchased a used outboard recently and noticed the pull cord won’t budge while attached to the flywheel but when I remove it from the shaft it pulls just fine. Flywheel DOES turn freely by hand.
Boatguy32
I’m having a hard time even finding parts for this thing. Any particular site? I’ve checked boats.net and Crowley marine with no luck.
Boatguy32
I guess I’m going to get back to the pull start at a later time. Come across some more issues. I was told there wasn’t spark to one of the plugs so they purchased the coils ( I hope the right ones?) and when I took the flywheel off, the existing wiring was in no way hooked up whatsoever so I don’t know where each wire goes now. I normally take a pic as I’m tearing things apart but now I’m a standstill. I’ll take a pic later in hope y’all can help out
Boatguy32
Trying to change coils but don’t know how the wiring is suppose to be. It was not done when taking the flywheel off so I don’t know how it goes! Help!
jerryjerry05
Shift interlock rod not a cable :(
#10 activates #1
The Force power
Are you sure it is a 1991 ? according the website I'm looking on they made them 1984 - 1987 & 1996-1998
