Mercruiser ECM replacement?
alldodge
Ebay injectors in most cases are junk. Injectors cannot be rebuilt cost effective. It cost more to rebuild one then replaced. Injectors can be cleaned and then tested to determine if they can be used, but not rebuilt
To find out, have yours cleaned and flow tested
Tail_Gunner
Tail_gunner,
1. Yes the motor revs higher when in neutral.
2. Original Model number 17086237 GM Rochester 0x55, I bought a pair of remanufactured ones from eBay as the oem were way too expensive!
3. Don't have a clue! I used the propeller that came with the boat when purchased.
4. How can I help identifying what it is? Send some more pictures of the carb?
Many thanks,
Kostas
Just a quick question. Does your mechanic know your engine is not preforming correctly? If so are you sharing what's being posted here with him/ her?
I take it you have very little working knowledge in regards to marine fuel injection. Do not be insulted by those questions plzz . They are not meant to be at all. For that matter does your mech have working knowledge of marine tbi injection...
Ferrarakias
Dear tail_gunner,
Not been insulted at all. I have zero knowledge regarding marine fuel injection! Paid the best well known mercury mechanic in my area (Athens, Greece) to install the motor back in the boat and have it working properly. His conclusion was that I need a new ecm, as already told you in my first post. I'm reluctant to order a new ecm though through eBay as the cost is not irrelevant and in case it's not the correct one, it will only add to what I already paid the mechanic and all parts that were replaced.
All I ask from you is advice how to proceed and sort this problem out.
Please bear with me.
Kostas
Ferrarakias
Alldodge,
Please excuse me, injectors were used, cleaned and tested not rebuilt. I can find the ebay seller and let you know, but it's been more than a year ago.
Kostas
Tail_Gunner
And your overseas...First and foremost would be parts availability....it's very poor here in the US one can only imagine what it is like in Greece.
Perhaps Alldodge has the correct timing procedure for both Mefi 1 and two...I no longer have manuals and my memory is highly suspect. If posted follow those procedures to the letter. Marine timing is very unique, not at all like automotive...speaking to that...did you replace the distributor...they to are quite unique and very a bit over the yrs. One model yr will not function in other yrs.
Take a picture of your new Ecm...it has two identifying numbers...
1 the part number
2. The actual software installed for a spefic engine..and to take it further one can have a Mefi 1 hardware with Mefi 2 software.
Once the engine has been timed correctly and using the proper distributor you can attempt to bring it up to WOT. If it does not go there....well your going to need a code reader....Mefi 1 does have a knock sensor and a engine protect mode. Both will keep the engine from developing full power.
Below is a pic, see the bar code and the numbers below it? Those numbers indicate the tune inside the Mefi housing.
Tail_Gunner
Ferrarakias
If you find the block casting number it can be looked up at mortec.com
alldodge,
Found some casting numbers:
*0266*
GM 5.7LG SGI
Are these correct?
Can Chris please advise whether the correct ecm is indeed 861078T1 for the roller cam?
Kostas
alldodge
The casting number has more digits. Should have commented at the time, but the arrow in Chris pic is pointing to the wrong location. Look below the distributor on the port side. The number will be at least 6 digits
Lou C
The casting numbers are on the rear end of the block, behind where the cyl head bolts on, this is a 4.3 V6 but the V8s are the same.... check both sides, this pic is from when I replaced the cyl heads back in '17. 1988 4.3 with roller cam. The V6s I think got the roller cam a little earlier than the V8s. The number in Chris's pic is a GM serial number, on the V6s it has a letter first that denotes the plant of manufacture, T=Tonawanda NY,
R=Romulus Michigan. 1st pic is the actual # on mine. On most they are behind the driver's side cyl head.
Tail_Gunner
alldodge,
*0266*
GM 5.7LG SGI
Are these correct?
Kostas
alldodge
Its from a 1998 5.7 EFI which is a roller cam motor
If (the big if) it does work, it should work for your motor. Would like to know the casting number to help clear up some uncertainty
Tail_Gunner
Mortec will identify that block in all the avaible combinations. 2bolt main/4bolt main...roller cam vs flat tappet.
Make this simple, take a pic of your valve covers, there are vortec heads and non vortec. If you have vortec heads then you have a roller cam if you do not have vortec heads you have a flat tappet.
Vortec valve covers have a center bolt to hold them down. That is the key. Below have a look.See a pattern there?
Your serial numbers show your engine in a transition yr...
Tail_Gunner
Gents,
Have just found this listing
Will this work with my engine?
Please let me know.
Kostas
Probably not, call or contact the vendor and ask point blank if the unit has software in it. Ive taken some time to look at those old Mefi units on eBay. All the units i have seen do not contain any programming what so ever. Your tinkering with history here and it will be a journey...expensive at that.
Below is a link to have your existing Eck reprogrammed. By far more accurate reliable and less expensive. Flea Bay is not a place for such purchases. Call them talk to them, they are intelligent and understanding. For that matter I am quite sure they have done work in your own country many times.
Ok Gunner now you done it.
As to your injectors, below is a link to the proper injectors.
Bingo
Lou C
Vortec engines have 8 bolts holding down the intake manifold whereas pre Vortec engines have 12 bolts.
alldodge
Post 1, pic 3 shows center bolts holding cover
Tail_Gunner
Lou cleaned it up, it's the intake bolt pattern. 8 vs 12. I'm quite sure he has Tbi heads but one never knows. And vortec heads vs tbi heads is a big deal in programming a file.
Again a picture of the intake/valve covers will define things so you can move move forward. Or just count the bolts holding down the intake.
8/vortec
12/ tbi
Ferrarakias
8/vortec
12/ tbi
Have some pictures in file, any definite conclusions? :)
