Lou C
- Nov 10, 2002
- 13,977
I think boats today while harder to service seem to be better built vs the older wood core/fiberglass construction. My neighbor has a 2005 Key West 2020 DC with a Yamaha 150 and the boat and structure look nearly new. Fully foam filled so it is also safer than older boats. She's owned it since new and it's been a very low maintenance boat for her. Agreed that 80s Bayliners were not built well at least not the smaller boats. The large ones seemed to be better built. However most other mass market boats in the same size range weren't much better than Bayliner. After 15 years the rot really starts to take hold with that type of construction unless you are in an arid climate. Here we have more or less constant moisture so wood/glass construction with carpeted decks and lousy lay up lasts 10-15 years before the deck rots. When I re-did mine I got rid of the crappy carpet and had the deck done in non-skid gelcoat and it is still solid 15 years after it was done, because the moisture can evaporate. Carpet decks over wood will always rot in this climate.
The NLA parts issue is not confined to OMC by any stretch. If you look back 15 years you will find NLA parts for Merc and Volvo too. Especially ECMs for EFI systems and electronic ignition. In fact a few have had to convert back to a carb from EFI due to NLA EFI parts for Volvo.
To me owning an old boat is like owning a classic muscle car or hot rod. Keeping some parts on hand is just part of it. Got a nice Holley 4160 4bbl sitting on a shelf in my garage, spare Prestolite points distributor, spare mechanical fuel pump the spare drive, complete transom mount, exhaust Y pipe, trim lines, pump, basically all of it. The sum total of investment of spare parts is less than $2000. I buy stuff when I see the price being right and I know I can re-sell it if I don't need it.
