Old ford 302 no spark
I went out to boat and figured I'd give it a quick flash up....2 knocks and then none..only ran for a min...it smelt gassy
Check if your fuel pump diaphragm ruptured
Jakem
It does seam to make more noise then the original that was in there and it doesn't have the 2 diagrams either just brass and one peice
Scott06
That doesn’t sound like a marine fuel pump , did you get an automotive one
Jakem
I told the parts guy it was for my boat but I guess that doesn't mean that's what I was given. If it is car can that really cause this much headache
alldodge
Using a auto pump is a safety hazard and not allowed by USCG regulations. The marine type has a double diaphragm and a fitting which will feed gas up to the flame arrestor into the carb. There is no other difference between auto and marine otherwise. Could be used for testing but needs to be replaced later
Now if the parts store gave you one which was not designed for the motor it may be pumping at higher pressure and flooding the carb.
Jakem
I will order the one that came off the engine in the first place. It had a sight glass as well wich said if there gas it's broken and replace...that's why I changed it....I will start from scratch with your suggestions
Jakem
I was told today that I need a 3 ohm coil and not the 1.5 for my points setup..any truth to it
alldodge
The coil should be labeled "use with external resistor"
Your motor should have a resistance wire which is connected to the + side of the coil. It will look like a normal purple wire but it has 3 ohm resistance built in. There will also be another wire which comes from the starter to give it full power
Jakem
Is this resister wire same as the one going to choke
Jakem
I spun engine around and piston is at top. Rotor is pointing to number 1 on cap. This is timing mark
I would use a piston stop tool to verify you are indeed on TDC
however it looks like you may need a new harmonic damper (or your piston is not at TDC)
normally to replace that, there is not enough room in front to get a damper puller tool in there. the motor may need to come out.
Jakem
How far should mark be away from pointer. I can't see any degree marks besides the yellow marks
alldodge
It should be dead on it. When a timing light is used, the pointer aligns up with the additional marks on the balancer. There are other marks with numbers. Your looking for 6 or 8* BTDC when running
kenny nunez
Put a small wire wheel on a drill and clean the rust and dirt off the balancer.
There will be ATC and BTC stamped on it with the “0” prominent plus the degree marks. Should be 10, 20, 30 with straight lines between the numbers.
Jakem
I found the stamped numbers on balancer...complete opposite side of were those yellow marks are. The piston is not at the top with the pointer on the zero. It's at bottom or there abouts
Jakem
Here is pic
alldodge
Need to remember you have a Ford and not a GM. Number 1 cylinder on a Ford is front starboard side
