78 Gamefisher 7.5HP Weak Spark !?!?
Gamefisher 7.5
I just picked up a 7.5hp gamefisher.
I have great compression, cleaned the carburetor, pulled it a few times with the original spark plug and realized it has low spark. Also I'm not sure where to get parts from ? Can anyone help me out with some info thanks!
brim_buster
First of all is it a points motor or solid state? Do you have a model or serial number? What parts are you looking for?
Gamefisher 7.5
Okay! And Yes I do sir, thank you for the quick response.
Model I believe is 217-585930
Serial is 3B-182512
Gamefisher 7.5
Serial is 3B-182512
Also I'm not sure, it seems to have 2 black half moons,when I take the flywheel off, with 1 wire running to a (coil?) on the side of the head, where a spark plug wire goes to the spark plug.
brim_buster
Thats what a solid state motor looks like when you pull the flywheel. If thats the case then either the SSI is weak or you have a bad wire or something going on
