Hard start and bogs in full throttle
OldSkoolFloater
Hello all. My 1977 Johnson 115HP outboard is giving me the blues. It is model 115EL77S. Lets start with the history.
I bought it as a project 4 months ago. Previous history unknown. Is on a 18" bass boat. Replaced head gaskets, rebuilt carbs, new fuel pump, new impellor and housing, new primer bulb, cleaned out gas tank, new spark plugs, one new coil, all spark jumps 7/16" gap, new power pack. Will start with muffs on and accelerate fine. A little hard to start after warm. Compression is all cylinders at about 115.
BUT, in the lake starts and will idle fine. Start to accelerate and it dies. Spraying ether into the air intake as you accelerate makes no difference. But, if you choke the engine it pushes past the problem within 300 rpms and can run at full throttle all day long.
Thus, I see the idle circuit seems to be working, and the jets are flowing at high speed. It seems to be a carb problem to me. I am wondering, is there a specific carburetor mounting wherein the bottom carb is possibly mounting at the top and causing the issue? A jetting issue?
Boat runs at about 40-45mph when on the lake. Can do a couple of laps and is fine. Drop it back down to idle and try to power back up and it dies.
I'm at a loss. Does anyone else have a solution I haven't thought about? The carbs seem correct from images I have seen. There were really clean when I opened them up.
Sounds like throttle plates opening too early.-----And most motors rev up in neutral on a hose.-----Means nothing.-----Perform procedure know as ---" link and sync " on this motor.
OldSkoolFloater
Great advice. Will try that next. Thanks.
oldboat1
Remove the screw plug on the side of the carb bowls, and clean the jets underneath with a piece of soft wire, followed by carb spray.
OldSkoolFloater
Do you think that they could possibly be clogged with it running full out around the lake twice?
Have you checked for water in your fuel ?----Have you looked at the ----Link and sync----Procedure , yes or no ?------Do you understand how important it is for proper acceleration of your motor ?-----What elevation are you running at ?-------If fuel hoses are old and brittle , pieces can break off and block fuel flow to carburetors.-----So yes , running around the lake twice can block carburetors.
OldSkoolFloater
I began the link in sync yesterday and discovered the timing mechanism did not move very freely. I remove the fly wheel, and inspected the stater and timing mechanism. The timing nylon bushing thing had some nasty-thick dirty grease on it. Also, the wires to it were binding and preventing its movement. Cleaned it up and readjusted all wiring. Put it back together last night and will complete the link n sync tonight.
BTW…all fuel lines are new from the tank to the carbs.
