Phantom309
Thread starter- Joined
- Sep 10, 2021
- 19
I recently bought a bass boat (1987 Procraft 1780) with a Mercury Black Max 150 XR2. After doing a bit of work adjusting the timing, we finally took it out on the water yesterday. At first it was running great, and we were cruising around getting to know the boat as well as the lake. (First time boaters aside from a jon boat in a small river).
While running on a plane at full throttle, the alarm went off. Checked the gauges, which honestly I had not been monitoring closely, and the temperature was high, as was water pressure at about 40psi. I immediately backed off the throttle and shut the motor off. Waited a few minutes and fired it up again. Temperature had gone down some and the alarm was not sounding any more. We kept it slow back to the dock as it was time for us to leave at that point. At idle, the water pressure is about 10 psi. Full throttle it was 30-40. I’ve read this is high.
From what reading I’ve done, it would seem that I have a blockage somewhere in the cooling system, reducing water flow which is causing the high pressure and temperature. Where should I start on trying to find the blockage? Poppet valves? Would a stuck poppet valves cause the high pressure at idle?
Is there an easy way to set up a secondary temperature and water pressure sensor? I’d like to verify that the gauges are correct. Most of the other gauges are either non functional or very inaccurate so I do not put much faith in them.
I plan to do the work myself. I’m a fairly decent auto mechanic, just pretty new to boats.
