DiveBoatSeattle
Thread starter- Joined
- Aug 2, 2021
- 11
Bought a 92 Capri 10th Anniversary for $400. Upholstery great, glass is great, trailer great. The bilge / engine compartment was a mess of black and funky. Cleaned it up and did most all of what I thought was needed. Marvel in the cylinders, replaced the starter, alternator, cap, wires and plugs. New carb as the throttle shaft was seized. (If I were more skilled I would have rebuilt it)
Got it to rotate with just a screwdriver on the fly wheel. "Fxed" the leak that was "coming from under the the exhaust manifold" with a new manifold gasket. Got it together that night and ran it 10 minutes with great temp and oil pressure on the the muffs. Lemons into Lemonade!
The next day discovered all the black water in the ski locker bilge. Haha!..Just like you all knew... Big "smile" on the side of the block.
Found a long block from a reputable shop. The mechanic asked questions and asked for a pic of the exhaust manifold and matched the head to my existing manifold on an 86 block. Made the 6 hour round trip to Rose Oregon and dropped it in the next day.
The old set up that ran, and always wanted to run, had short plugs, new NGK BP6EFS's, if I have that right. Talked with the mechanic I bought the new engine from and he recommended the new one get Autolite 140 plugs, as it has the deeper reach. I moved everything from the old set up over to the new long block. Have tried and tried to get it to fire up. Positive I have TDC and the rotor set up on 1 with 1342. New battery that I keep on a tender and still just puff, puff puff... No Pop, Pop, Pop and no sign of starting. Spark confirmed on 1 and 4. Gas at least up to the new carb. Could I have a low spark issue with the old ignition coil? Maybe wrong plug or wrong gap at .045? Little smoke out the carb. I pulled the plugs and cleaned them twice as they looked wet and a bit blackened.
Any thoughts or things to try?
Thanks in Advance! iBoats and the Youtube have already been fantastic resources on my learnin journey.
