GARMIN FISH FINDER & UNIDEN RADIO WILL NOT TURN ON PLEASE HELP!!!
Newportboatnoob
First off if you are reading this THANK YOU!! There have been so many cuss words trying to rectify this problem.
the boat in question is a 2016 scout 210 xsf
So after a rough day out at the seas.. the garmin 94sv and as well as the uniden radio will not power on at all! This all started to happen when one of the grounding cables got stripped from the crimped end on the battery terminal. The same ground was also used to start the boat.. so I know it’s not that ground since boat starts with no problem.
I went in the cabin (behind dashboard) and there is a power and ground conjunction box which hooks up the power and the ground to the fish finder and the radio.
I checked with a multimeter and I’m at 14 volts when the MAIN grounding cable is unplugged from the box. BUT when I connect the grounding cable to the conjunction box I’m only getting just over 2 volts..
can someone please tell me how to fix this please so I can stop being mad at the world and also keeping bullet rye in business!!!! 😅😅
Newportboatnoob
Here is the conjunction box I am talking about
dingbat
This is factory wiring?
If so, they need shot. That’s a buss bar, not a distribution panel.
Motor running while measuring 14V? Should be 12.7V or thereabouts otherwise
Where are you measuring that you get 14v without a ground connection?
Sounds like your connecting ground to power or vice versa
While your at it get rid of the yellow fuse holder. Well known source of power problems
mike_i
Not that this will fix your issue but I would also have ring terminals on all of the wires. Have you checked the fuses? You wouldn't be located in newport beach ca. would you?
Scott06475
