1975 Johnson 115 hard to start when warm
Rob the Dob
My old 115 runs great but if you anchor up for 15 or 20 minutes, it no longer wants to start. Any ideas would be helpful. Thanks!
Check for strong spark when motor is hot.----Or have battery load tested.----Or pull starter apart and inspect brushes.---Do ohm check on armature.----No money spent so far.---Your choice.
Rob the Dob
Thanks, doesn’t seem to be a battery or spark issue. Strong turnover during cranking and plenty of spark. Almost seems to be flooded. If I unhook the fuel line and crank some gas out it fires back up.
I believe you have diagnosed the problem.-----I missed that information in post #1---Sorry.
Rob the Dob
I’m glad you recommended the spark check and glad that’s not it but I’m still a little lost on a fix for the flooding issue. Any ideas on a fix for this?
Thanks
