MillerIsTall
Thread starter- Joined
- Aug 10, 2021
- 7
I have a 1977 Johnson 85 outboard that is not producing Spark on cylinder 4. At the beginning of the season I would store the motor tilted all the way up as I was fairly close to shore. When I would take it out it would not seem to want to fully open up for about 10 or 15 minutes. Thought maybe it was flooded from storing motor tilted. As I would be driving the motor would kick the full power and I would be good for the rest of the day. Last week I took the boat out and it was running fine and after about a half an hour of driving I lost power like I previously mentioned. I clean the carburetors thinking I may have sucked up water and cleaned it fuel lines completely along with the tank. Took the boat back out and it was still performing the same. Went to do a compression test and noticed cylinder for spark plug was wet and fairly clean. Compression test was even on all cylinders. Did a spark plug test and was getting no spark from number 4. Spark plug works in the other three Leeds. Changed the coil pack and problem was solved....for the day. That was yesterday. Today went to take the boat out and it's doing the same thing, no spark on cylinder 4. What should I look for next? CDI?
